LabVIEW Embedded
"Deployment completed with errors" message when deploying to cRIO-9045 with "Enable Embedded UI" ticked
I am encountering the "Deployment completed with errors" message when attempting to run a VI onto a cRIO.
My setup is:
Windows PC = Windows 11 64-bit running LabVIEW 2024 Q3 (24.3.2f2) 64-bit
cRIO = cRIO-9045. Firmware Version: 24.0.0f131-x64; Operating System = NI Linux Real-Time x64 6.1.108-rt40.
After several tests I have proof that the "Deployment completed with errors" message appears only when the Enable Embedded UI setting is ticked for that cRIO in MAX.
When that setting is unticked, the exact same VI deploys and runs fine.
I have replicated the issue on two different, but extremely similar/identical setups. In other words, two pairs of Windows 11 PC and cRIO-9045. The two cRIO-9045 are running the exact same firmware and drivers (same image extracted using the NI RAD tool). The issue occurs identically on both setups.
I am able to deploy a simple test VI without any issues both when the Enable Embedded UI setting is ticked or unticked. In other words, the setting does not prevent deploying all VIs, in particular it does not prevent the deployment of a simple test VI. But it does prevent the deployment of a larger VI (the main VI) that depends on several lvlib's and lvclass'es.
I would like to use the Enable Embedded UI setting because I want to be able to use Tester VIs that use Value Change events (button presses) to trigger certain actions. When that setting is unticked Value Change events (button presses) are ignored on the cRIO.
Has anyone faced the "Deployment completed with errors" message when using the "Enable Embedded UI" option? Is there any way to get more information on what VI, lvlib, or lvclass specifically causes this message?
Many thanks for any help.
Note: This post is related to this post from 2016.
(1,470 Views)
I also get the Deployment completed with errors message, I'm using myRIO on labview 2019, I'll leave a pic of my program so you can look at it. Do you have any solutions?
(1,268 Views)
I don't know why you are getting the "Deployment completed with errors" message. Your VI's block diagram doesn't seem to contain anything that would cause that issue.
You might find the following resources useful:
1. What is the root cause of "...loaded with errors on the target and was closed" error when deploying ...
2. HSE DocuWiki - Deployment
3. Deploying to cRIO is effectively impossible
The three links above are closely related to one another. The comments to the first link detail what worked for me and made the problem go away, which, in short, was to make sure that my project (my .lvproj file) contained a single CompactRIO device. I was getting the error when my project contained two or more CompactRIO devices.
(1,257 Views)
Hello
How were you able to fix the enable embedded UI problem, i also need it for my project, but it is only when i untick it that is when my RT vi will then deploy without errors.
(1,009 Views)
Hi Dharmiee,
My advice would be:
1) Read the three resources listed above. The links numbered 1, 2, 3. There is a lot of information in those resources.
2) If you are experiencing a behaviour that is not described in those resources, take screenshots of what you are seeing and post them below.
Deploying to cRIOs can sometimes be difficult, as described in those resources.
(996 Views)
