LabVIEW Embedded
read and write to eeprom ds2431
I use cDAQ9181 and NI-9237
I have 10-position connector. Positions A, B, D, E are for my PR-Accelerometer. Positions C, J, G, K are for my strain gauge.
Position F is to pin T0+ of the NI-9237, and position H is to pin T- of NI-9237.
Position F is soldered to Pin 2 of Eeprom (1-wire data)
Position H is soldered to Pin 1 of Eeprom (GND)
Pin 3 of Eeprom is trimmed off.
I use "DAQmx Write TEDS data.VI", wiring in a bitstream of 32 bytes (bytes 0-7: Strain Serial #, bytes 8-15: Strain Calibration, bytes 16-23: A #, bytes 24-31: A Cal) to AcivePhysicalChans="...Mod1/ai0". However, there is error -200709.
Is this because my DS2431 is bad? or because I don't know how to write data to this blank eeprom?
Please help.
(1,192 Views)
never-mind. I figured out. I installed NI CompactRIO Download
then used built-in functionngthai_0-1767565180126.pngngthai_0-1767565180126.png
(1,168 Views)
