LabVIEW Embedded
receiving SMS using GSM module in LabVIEW
Hi ...
I am Communicating the GSM module in VI. I can found the solution for sending the SMS. But i am having the trouble in read the SMS in VI. I tried more type of models. When I am running the VI,  in the read buffer content is displaying as "AT+CMGR=1" which is we are writing AT command into the port for reading the SMS.Here I attached the image.... please kindly go that image, you will surely get what I am getting the error...
Please reply asap....
Message 1 of 10
(20,081 Views)
Please attach the vi. that you had used for sending the sms.
Message 3 of 10
(16,220 Views)
Here vi for receiving SMS from GSM....
Message 4 of 10
(16,073 Views)
Accepted by azadplc007
Here vi for receiving SMS from GSM....V14
Message 5 of 10
(16,071 Views)
hello
can you send your VI file to send the message
Message 6 of 10
(14,195 Views)
hello
can you send your VI file to send the message.
I am created my VI file for sending SMS but there are some mistakes.
plz provide some solutions
Message 7 of 10
(14,195 Views)
hello rajbag,
I have modified your coding, check this coding once....
Message 8 of 10
(14,185 Views)
COOL!  😃
Where can I open the GSM module inside LabView?
Is there also a 3G cellular module?
Message 9 of 10
(13,281 Views)
You can't open the GSM module with this code. We are communicating the GSM module using VISA commands. Refer google for most AT commands for the GSM module.
Message 10 of 10
(13,165 Views)
