LabVIEW Embedded
run labview app on linux
I got runtime libraries from the following link
http://joule.ni.com/nidu/cds/view/p/id/1391/lang/en
I converted the above rpm package into debian package.
I installed debian and i am sure labview run time is installed(synaptic packet manager)
Still i am not able to run labview executable on my linux machine(ubuntu 8.04)
So pls reply ASAP
Sriram Iyer
Message 1 of 11
(9,944 Views)
How did you generate the exe?
You need to do this in the linux environment, not windows!
greetings from the Netherlands
Message 2 of 11
(9,942 Views)
I created exe on windows and I am trying to run the same on my linux machine.
Exe was created by App Builder.
Message 3 of 11
(9,941 Views)
That will not work because all calls to the operating system are wrong.
Message 4 of 11
(9,937 Views)
Thanx for ur reply..
Tel me how to run my app on linux machine..
Do i have to install separate run time engine. If so let me know the link.
Sriram Iyer
Message 5 of 11
(9,936 Views)
I have installed labVIEW runtime engine for linux
And if i run the executable,the following error message pops up
"Unable to locate the labVIEW runtime engine"
Sriram Iyer
Message 6 of 11
(9,930 Views)
Hi
The windows app is so nice to tell you that it cannot find a windows runtime. It should have said wrong operating system.
You have a correct operating system and maybe a correct runtime but maybe installed in the wrong directory. But anyhow a wrong .exe file.
As I said before you need a linux LabVIEW version to generate an exe for linux!
Message 7 of 11
(9,928 Views)
I have installed cygwin software to build the app in linux console.
And its working nicely.(this is done in my windows machine)
I want to take that .exe and run in my linux machine.
Is it possible?
Indumathi
Message 8 of 11
(9,909 Views)
Cygwin is the other way round. Or better said the diode is in the wrong direction. Cygwin makes it possible to run linux programs under windows.
What you are trying to do is running a windows program under linux!
The answer is the same: Get a linux version of LabVIEW recompile your source and it will run !
Message 9 of 11
(9,907 Views)
I have created the app in windows machine using cygwin i can build and run the same app.
So,Now apphas become linux application right,So it should work under my linux machine also.
Anyway,cygwin is creating all the runtime libraries tht support Linux.
Is my thought right or wrong?
Indumathi
Message 10 of 11
(9,906 Views)
