 gsussman
			 on
		08-26-2010
		10:14 AM
			1 Comment (1 New)
			gsussman
			 on
		08-26-2010
		10:14 AM
			1 Comment (1 New)
		When you configure Memory in LV FPGA, there is no way to find specific references to particular memory blocks using the search function. The search will show "ALL" memory access nodes, not just the ones you are looking for. Additionally a text serach will not catch the text from the X Nodes. This can be particularly tedious if you have many nodes in your hierarchy and are looking to only see references to a particular memory block.
I would like to see the search improved to allow filtering of the memory nodes the same way that we can search for global variables (find definition and find references)
