| User | Kudos |
| 14 | |
| 3 | |
| 3 | |
| 2 | |
| 1 |
I often add comments to BD to describe specific behaviour depending on different states which would be best within a table. At the moment there are a view ways to do so:
1. Using normal comments and spaces to add a table-like design - not so good
2. The same as 1. but using a font like Courier or Terminal together with "|", "+" and "-" - better
3. Using a 2D-String array - don't like this
4. Do it in Excel and add a screenprint in BD - don't like too
I think the best way would be the possibility to have a 2D-Comment where you can add columns and rows together with header.
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
