It would be nice to have the possibility to draw comment-like areas on the BD to surround specific code so it is fixed with in this area and exclude the code from program cleanup and adds a label to comment. While using Diagram Disable Structures I change the dataflow and to prevent this a "RubberPad" without tunnels could help.
