7 | |
6 | |
2 | |
2 | |
2 |
Hi
The customer want to show our 3D graph in rectangular. Which is base on 1 axis's scale.
For example, below graph's Z axis is -5 to 1, but we see it's same length as Y axis from -5 to 5.
So they want Y axis length stay the same, but Z axis is shorter. Which the result can be a rectangle 3D cube.
best regards,
Steve
