altenbach
A Caching Structure!
Status: New
I often have a situation where certain code parts don't really need to be recalcuated, because their inputs have not changed from an earlier encounter.
For example if a function is the sum of two different complicated and slow calculations where each of the two depend on a different subset of parameters, often only one needs to be recalculated, while the other intermediary result could be grabbed from a cached value. (This occurs for example during the calcuation of partial derivatives).
In some cases, the compiler could probably recognize these situations, but I think we should have a special structure to allow caching of intermediary results.
I typically use a case structure and two feedback nodes as shown in the example on the left. If the value is different, the code in the TRUE case is executed, else the value stored in the SR is returned immediately. (If the code depends on several values, I bundle them all before the comparison operation)
I propose an simple Caching Structure as show on the right that retains that same functionality with less baggage.
Details: The containing code is calculated at first run and stored in the output tunnel. In later calls, it is either (A) recalculated, or (B) the previously stored value returned at the output tunnels. Recalculation only occurs under some conditions (.i.e. usually when actually needed)
The structure has the following features:
  • Two possible types of input tunnels (the functionality is indicated by a different look).
    1. One where a value change triggers a recalcuation of the containing code
    2. One where a value change does not trigger a recalculation of the containing code
  • A special boolean terminal to force a recalculation unconditionally
  • output tunnels that retain data between calls
There can be an unlimited number of input and output tunnels of any type described above. A recalculation of the inner code occurs if any of the triggering tunnels have a changed value.
We can think of it similar to "short-term folding".
22 Comments
elset191
Active Participant
Well, sorry for getting your hopes up.
I was looking at a subVI within the subVI I thought was being automatically cached (which it's not).  I was getting fooled because the VI calls I was watching were in fact being manually cached.
My apologies.
Tim Elsey
Certified LabVIEW Architect
Dragis
Active Participant
Ha, sorry about my vague post before. When I said "compiler", I meant compilers in general, not necessarily the LabVIEW compiler ; )
The detection logic here is fairly straightforward, similar to how LabVIEW already detects constant blocks of code. The hard part is figuring out when to do it. That's where the structure would be a nice first pass so the user can explicitly tell the compiler where performance problems are expected. Then the compiler team can tackle the more automated process.
