altenbach
A Menu Entry to Clear Variant Data
Status: Completed
Available in LabVIEW 2020 and later. You can right-click a variant control or indicator on the front panel and select Data Operations > Clear Data.
I recently noticed that some of my fitting model VIs were excessively large on disk. It turns out that during debugging long ago I made the current values the default so I can run it standalone. This also meant that the data variant control contained a gigantic kernel matrix.
For some reason it is not obvious how to clear the variant (in order to be able to make the new value default and make the VI small again).
For example for the nonlinear fitting model templates, the data is not shown by default, obscuring the fact that it is the culprit for the excessive size. This also makes clearing the variant tedious (right-click...show data...select all data...delete...right-click...uncheck show data...).
IDEA: I propose a new menu entry: "Right-click...data operations...Clear Data" or similar.
See picture. Thanks!
10 Comments
crossrulz
Knight of NI
Similar to the Empty Array right-click menu.  Makes sense to me.
SteenSchmidt
Trusted Enthusiast
Yes, I've had to empty variants once in a while. Kudos.
CLA, CTA, CLED & LabVIEW Champion
DanyAllard
Active Participant
Good one. Kudos
LabVIEW ChampionArchitect
muks
Proven Zealot
kudos...Smiley Happy
AristosQueue (NI)
NI Employee (retired)
Alternate sequence of steps:
Drop new variant. Copy data from it. Paste data into existing variant. Make current value default. Delete new variant.
Still a pain but easier than the menus mess.
Kudos for the idea.
altenbach
Knight of NI
So, long after posting my idea here, Bob Price made a shortcut menu plugin (I missed that somehow) and this is what really should be in LabVIEW by default!
Ben
Knight of NI Knight of NI
Knight of NI
I agree!
As an itinerate wire-worker, I often find myself in front of a customer's machine inside of a barbed wire fence and no access to special code the internet or even a USB device.
If it is not built-in, it is of little use to me.
Ben
Darren
Proven Zealot
Status changed to: In Development
Darren
Proven Zealot
Status changed to: In Beta
Darren
Proven Zealot
Status changed to: Completed
