Labview allows you to change the cell background color but it does not allow the programmer to change the color of the horizontal and vertical lines. One thing that I am trying to do is make the table look like an indicator. Indicators usually have a light gray background color to indicate to the user that the item they are trying to edit is not permitted. When trying to change the color of the cells by using a different background color it washes out the horizontal and vertical lines present on the table. This option is not available on the silver table.
