6 | |
5 | |
2 | |
2 | |
2 |
There are some times I'd like to implement changes in a LVOOP hierarchy which requires making many repetitious changes in sibling classes. Since the sibling classes are similar but not identical, the ability to create ONE sibling class with the new changes and then calculate (and store) the Difference, these Differences could then be applied to ALL siblings essentially batch-editing a whole group of similar VIs.
I know scripting can help here but I'm thinking about operations on sometimes quite a lot of VIs and it's simply a question of the return on investment. Writing a scripting VI to do the changes takes a while......
Shane.
