11 | |
8 | |
3 | |
3 | |
2 |
It is not uncommon to have to restrict numeric entries to accept only either odd or even values. It would be nice to be able to specify that behavior, for example in the Data Entry tab of the Properties dialog, so we don't have to write some code to enforce that restriction, with the Response to value outside limits to either round up or down. This would apply to integers only.
