13 | |
11 | |
3 | |
3 | |
2 |
I think the Array Element Gap should be sizable. This would facilitate lining up FP arrays with other items on the FP, or simply as a mechanism to add more apparent delineation between elements.
The size should be set in the Properties box, not by dragging the element gap with the mouse - that would add too much "cursor noise".
A new Property Node for this feature would complete Idea.
