For example, if I had a case structure with 50 cases and one variable in each case, I would like to be able to copy the case structure and have a new identical case structure with 50 matching local variables. Currently it makes 50 new variables, so having the option to choose between generating new ones and generating locals of the existing would be extremely useful.
