I feel like frustrated when there is a lack of connector in the existing VI and need more
. Because, when I update it to new pattern as shown below, I need to update the VI's instance in all other VIs in the project. Since I am updating the pattern from lower number of connectors to the higher number of connectors, it would be better if all the instances in other VIs get updated automatically
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
