Hi all!
I know the title doesn't make sense, so I will try to explain.
I think it would be a good idea to have a way to define values similar to the C instruction #define. In C code, you can define constants and change its values all over the code during development time.
Right now, there is nothing like this in LabVIEW. You can use controls and variables, or controls and property nodes.
(Strict) Type Defs for controls have kind of the same philosophy, you change things on a single file, while all the instances are updated (but there is no way to define a single value for all the instances of a control). I guess in LV it would make sense if we could define a constant file, and place it in every block diagram that we want to get that value.
Don't you think it would be a good idea?
I tried to define a Strict Type Def with a range where only one value is possible, and the coercing options. Anyway, the behaviour is not what I expected, as it seems that the control doesn't look at its own properties until you try to change its value. If the control has a default value of 4, and you change the valid range to [5,5], the control will have the 4 value until you try to change it (and then the value will be coerced to 5).
I don't think that is a good behaviour, do you agree?
PS: I think it would be great to have a "User Defined Type Def", in which you could define the things that stay the same and the thing that doesn't, but I know that idea is not mine :D.
Regards!
