 jlokanis
			jlokanis
		 on
		07-30-2009
		01:45 PM
			3 Comments (3 New)
			 on
		07-30-2009
		01:45 PM
			3 Comments (3 New)
		NOTE: This is blatently stolen from a thread I started on LAVA here.
I would like to be able to specify a VI or VIs in my project that would run when some keyboard shortcut (ctrl-shift-R was suggested) was pressed.
Since in most cases a project is used to create a single application, it makes sense that when you open the project, you would want ot run the top level (main) VI in that project most of the time.
