13 | |
11 | |
3 | |
3 | |
3 |
LabView Control and Simulation Design Toolkit
-A simulation subVI fails to compile if an initial condition of zero exists on an integration block.
IDEA: Run a zero initial condition check on a system before attempting to compile. If the condition exists, don't attempt to compile and report the problem to user.
-A simulation subVI fails to compile if a change is made after the subVI is created.
IDEA: If a change is detected in the subVI, force the subVI to recompile every time a file command is implemented.
