The context menu for a file in the project window always contains the entry "properties" - but the dialog that stays behind is different between LabView-Files and non-LabView-Files. e.g. for a VI the VI property dialog opens, for a TXT-file the windows file-property opens. With other words: I can't open the windows file-property-dialog for LabView files.
I would suggest to have an menu entry "file properties" that opens always the windows file-property dialog. The current "property" entry can disappear for non-LabView files.
Remark: I'm using LV2011SP1
