With using of
„\vi.lib\picture\bmp.llb\Read BMP File.vi”,
it is not possible to load a BMP file with negative height in BMP header. VI returns an error. Please update “Read BMP File.vi” to support complete BMP standard. Negative height in BMP header meaning that the bitmap is a "top-down" bitmap (the image data starting with the top pixel and end with the bottom pixel). Attached is one such image.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
