| User | Kudos |
| 14 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
When entering debug mode (turn execution highlight on) it can be hard to see what is happening.
With event structures it can be hard, but there are subtile changes. Sometimes it's impossible. For instance, if you run this VI, and wait a while, it is impossible to why the VI has not stopped. In this case it's easy to deduce, but it can be really hard. Probes also don't provide a solution here...
SubVI's get a green arrow when they are executing. So, could structures get them as well?
