| User | Kudos |
| 11 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
Life can be a real beach when working on a load of high-performance VIs which have a bug somewhere. First spend half an hour un-setting "Subroutine" on a tree of VIs, then find the bug, spend another half an hour re-enabling sub-routine execution and then spend a further half an hour finding the last subVI you forgot because you've noticed a problem when benchmarking...... ![]()
How about setting a VI to conditional subrouting meaning that it retains its subroutine status until you place a probe or breakpoint in it (It would be nice if calling VIs adapted also of course). As soon as the breakpoint / probe are removed, return as normal to subroutine execution. Man would this save a lot of time.
Shane.
