8 | |
5 | |
4 | |
3 | |
3 |
I like the new event dialog (three pane) of LabVIEW 2009, however one issue is still missing, it would be very usefull if we could at an event case from this dialog.
With this new option we could set up a lot of events we want to react on in a single dialog.
Ton
