13 | |
11 | |
3 | |
3 | |
3 |
From trying to make a malleable VI for some set/map functionality, I cannot seem to find a good way to cause the VIM call to be broken for when the input is not a set/map. It would be helpful to have a Asset Set and Assert Map method added to the Assert Type palette for this.
Declined for reasons listed in AristosQueue's replies
