11 | |
8 | |
3 | |
3 | |
2 |
I have a project which compiles to 2 different executable for different hardware targets. I have created 2 Build Specifications which specify different locations for the build output. However, between compiling each one, I must go to the target options, and change a Conditional Disable Symbol definition so that the other .exe is generated. If the Build Specifications definition had a tab to specify the value of Conditional Disable Symbols, and which would take precedence over definitions in the project or the target options, then I could build my 2 executables without changing the target properties.
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Conditional-Disable-Symbols-settable-in-Application-Bu...
