Blokk
Copy diagram to case (extra option next to the "Swap Diagram With Case")
I often have a Case structure, where I have all the cases created, but they are empty. I start to work on a case, and to speed up the work, I would like to copy the same content to another case, for further modification. I know I can just use the "Duplicate Case" option, but in this way I have more extra steps to do: either typing in or copy/pasting in the selector label of the target case, plus I need to delete the original case (since in this way I will end up two cases with same selector labels).
If we had an option via right click: "Copy diagram to case", this would make all this just much faster and easier!
9 Comments
Mythilt
A Plugin could most likely be written to do this if desired.
Jon D
Certified LabVIEW Developer.
Blokk
Trusted Enthusiast
Could you direct me pls how I can make such plugin?
AristosQueue (NI)
NI Employee (retired)
Instructions for writing new right-click menu options are at the bottom of this page under the heading
"Creating Shortcut Menu Plug-Ins"
https://zone.ni.com/reference/en-XX/help/371361M-01/lvhowto/shortcutmenuplugins_intro/
Note: Just because this can be written as a customer plug-in does not negate the idea of LabVIEW adding this ability natively. The idea remains open for comments and kudos.
crossrulz
Knight of NI
LabVIEW Shortcut Menu Plug-Ins
and somewhere in there is the instructions: Read This First
Blokk
Trusted Enthusiast
Thanks for links!
X.
Trusted Enthusiast
Trusted Enthusiast
What about the Search function?
This is a duplicate of a duplicate... found looking for "Duplicate Case":
Add "Copy Case Contents To" right-click menu
new feature "copy case for every value"
Blokk
Trusted Enthusiast
I am sorry, before my post I only did a quick search, for sure I failed it, since I did not see those ones you show.
edit: so label this Idea as "duplicate", I voted for the other idea behind your link.
X.
Trusted Enthusiast
Trusted Enthusiast
No worries. It just sounded familiar, so I looked for something similar and had no problem finding it.
Darren
Proven Zealot
