3 | |
3 | |
2 | |
2 | |
2 |
When closing untitled VIs LabVIEW gives you a dialogue which prompts you to Save changes, Defer or Cancel.
If you Defer Decision then you have to select the VI in the project, remove it and confirm another dialogue prompting to save changes. This means that to close an untitled VI is a three stage process. This can be quite annoying when you have just created a small bit of test code that is no longer needed.
I propose having a fourth option in the original dialogue allowing you to not save the VI and remove it from the project and memory.
e.g.
