5 | |
5 | |
2 | |
2 | |
2 |
I really hate having to dig through a long hierarchy of menus when I know what I want:
Visual Studio (and other MS and non-MS products) have a feature called Intellisense, which is meant to make this easier. Basically, as you type, it pops up a list of matching objects, based on context, so you can quickly select what you want:
It would be nice if LV had a similar feature - click on a property in the property node using the text tool (or Ctrl+click if using the auto-tool) and now you can type in the property name and you will get an Intellisense-like pop-up, which will have all the relevant properties.
Specific features it could have:
This example (LV 2009) shows how useful this could be. You don't need anything installed. Just run the VI and start changing properties.
Caveats:
Note - this is similar to this idea, but I think that it's much more usable. Also note that the second idea refers to a QDKS which ships with 2010, but that is far from perfect.
