Similar to specifying the Access Scope for multiple VIs in a library by grouping them in a Virtual Folder and setting the Access Scope of the folder, I'd like to specify locking or password protection for multiple VIs in a LabVIEW library by enabling that on the owning Virtual Folder. The dialog would be the same as if you were setting the Protection on the entire library from the Properties menu.
