6 | |
6 | |
3 | |
2 | |
2 |
It would be useful to be able to name (either automatically or manually) the sliders of a Slide control (or needles of a Meter or Gauge). The use-case I have is for saving a configuration file (currently requiring typecast to/from a cluster with names), but it may also be useful to be able to Unbundle By Name. I found this post in the LabVIEW forums showing this idea has been talked about in the past also. Here's an image from that post:
A related idea would be the ability to replace the control with a Cluster control, and vice-versa. Currently, this requires creating a typedef and manually recreating the cluster.
