When concatenating arrays, a wired empty 1D array, concatenated to an Empty 2D array will result in array index (1,0) and when this is concatenated to a populated 2D array, a top row is added with empty elements. This is in many cases unwanted behavior.
The suggest that LabVIEW includes a menu to configure the concatenate array node to ignore acting on any empty array(s) wired to that node.
Because in some cases the resulting array will end up with an added top row with empty elements.
Anthony Lukindo
