13 | |
11 | |
3 | |
3 | |
3 |
The code below will execute without error or warning. The value returned will be 127 in this case.
Why is that? I understand the error 91 is returned if the typedefs are incompatible but if the type is different but compatible I would expect a warning maybe?
Cheers,
Jimmy
