13 | |
11 | |
3 | |
3 | |
3 |
Removing the selected Ctrl-Key Shortcuts by pressing one button would be much easier and comfortable then the current solution.
Right now, you have to delete the appropriate VIs from the directory National Instruments\LabVIEW xxx\resource\dialog\QuickDrop\plugins. Additionally, you have to delete the shortcut entry in the LabVIEW ini file within the key name QuickDropKeyboardShortcutMappings. Otherwise the shortcut is blocked for further use (see picture below).
With the Remove button you have the possibility to delete everything (Shortcut and all corresponding VIs) or just the Shortcut without the VIs remaining in the LabVIEW directory (Therefore, the Shortcut has to be deleted from the VI description).
