13 | |
11 | |
3 | |
3 | |
3 |
LabVIEW's units support angular measurements of degrees, minutes, seconds, radians and steradians but I don't see support for a full revolution. If this was added, we could use 'rev/min' as a unit which is a very common unit.
I think that users don't really use units as much as they might because of limitations such as this. There are some other things that I would like changed with units, but this should be and easy one to fix.
