I suggest to add the following tools to the Number/string conversion palette:
Number to Roman Numerals
Roman Numerals to Number
Here's how they could look like on the block diagram. A simple draft of these function can be found here.
Idea Summary: Add conversion tools for roman numerals to LabVIEW
