| User | Kudos |
| 6 | |
| 2 | |
| 1 | |
| 1 | |
| 1 |
Every time I need a variant constant, I have to:
1) Pick any function from the Cluster, Class & Variant functions palette>>Variant
2) Place it in block diagram and right click>>create>>constant
3) Delete function.
I believe the variant constant should be in that palette.
I did a search in the functions palette for "variant constant" and it is not there.
Please add the variant constant to the Cluster, Class & Variant>>Variant function palette 🙂
Fab
Implemented in LabVIEW 2014
