11 | |
10 | |
3 | |
3 | |
2 |
It is not obvious that a NaN numeric constant can be created by simply typing "NaN" as value. What we see are weird constructs, e.g. "zero divided by zero" or "square root of -1" to generate a NaN on the diagram.
I suggest to add a NaN diagram constant to the numeric palette to make it more obvious.
(This is just a quick draft. Of course it should be matched in color and design to the other constants)
Available in LabVIEW 2019 and later.
