| User | Kudos |
| 10 | |
| 6 | |
| 5 | |
| 3 | |
| 2 |
I was recently trying to develop a function to navigate thru a deeply nested directory structure and came across system path length limitations which could potentially be addressed by use of a "change directory" function.
I realize I could use system exec with cmd /c cd <path>, but found this extremely slow
