There are some dialog boxes in LabVIEW that I think need to have a "set as defaults" option available. As an example, there are a lot of form fields when building installers for my applications that need to always be the same (or almost always). In particular the "Version Information" section:
This is something that is rather minor. However, as a day-to-day LabVIEW developers, filling these fields out over-and-over again has gotten old. Thanks for your consideration.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
