hecmar.arreola
Change default build path to something other than "..\builds"
Status: New
Being able to set the default target build folder for anything I build in LabVIEW would be a nice convenience for me.  Currently, when a new build is created the default path is relative as "..\builds" from the current project folder.  I would like to be able to change the default to a physical root path to something like "C:\Users\<username>\LabVIEW Builds\".
3 Comments
Richard_Ha
I'd like this too so that I can set it to be within the project directory so that I can keep it with the source control version of the project.
crossrulz
Knight of NI
I'd argue the default should be ".\builds" so that it is within the project directory.
hecmar.arreola
Active Participant
I don't disagree with you, crossrulz, the default should be ".\builds".  But I'm not asking to change the default; I'm asking for the ability for the user to change the default to something else if they desire like a lot of other LabVIEW features/options.  Then if we desire ".\builds" we can enter it.  My preference is different than that because I share my entire build folder with other domain users, but I don't want to share my source code.
