We require to programmatically Add an EPICs IO server to a shared variable library like you can do manually from the project explorer as shown in the picture:
Currently, there is a way to create an EPICS IO server programmatically with the function but this function will not save the EPICS IO server on a Shared variable.
We require to save the EPICS IO server to the library, then save the library(.lvlib file) to disk so we can later deploy the library.
