6 | |
6 | |
3 | |
2 | |
2 |
After deleting items I don't want in the project, or loading plugins in a plugin architecture, I want to remove them from the LabVIEW memory. This is not possible now, as they go into Dependencies->Items in Memory.
The only way to do this now is to close and open the project, which over a large Plug-in architecture project is a real pain.
Ideally, I would like to right click the folder and choose "remove from memory". However, any option that allows this would be good.
Thank you!
Danielle
