| User | Kudos |
| 11 | |
| 7 | |
| 6 | |
| 5 | |
| 4 |
"<LabVIEW 20XX>\project\procmphier.llb\CMP Compare two VIs.vi" is an excellent VI that lets us develop tools to address some shortcomings of "raw" LVCompare.exe.
There should be a similar VI to open the LVMerge dialog.
The part of "CMP Compare two VIs.vi" that I find most useful and would be invaluable for LVMerge is the option to pass in different AppRefs, which lets us load different versions of VIs with the same name and compare them, thus providing a path to eliminate all the breakages associated with renaming files (eg "claims to be part of library," "could not find class with this name...").
There are some tantalizing VIs in "project\_promergevis.llb\NI_promergevis.lvlib" but there doesn't seem to be a public means to open the VIs in different application instances.
