LabView7734
Add built-in character-to-ASCII code and ASCII-code-to-character functions.
Status: Declined
In most every text-based programming language there are built-in functions to convert a character to its decimal ASCII code and a decimal ASCII code value to its associated character.  In BASIC, for example, ASC(character) does the former and CHR$(code) does the latter.  In LabView you have to implement these functions yourself from scratch with a CASE structure.  If you want to do the whole 7-bit character set you need 128 cases.  This is a waste of time!  Since many instruments use single ASCII charcters as their commands why not include such functions in LabView?
3 Comments
altenbach
Knight of NI
Why would you need 128 cases?? Just typecast from string to U8 or back.
(for multiple characters, we also have string to byte array and byte array to string)
PhillipBrooks
Active Participant
It appears that someone is in LabVIEW 7734 ...
Darren
Proven Zealot
Status changed to: Declined
