| User | Kudos |
| 13 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
When dragging a snippet onto the block diagram, its code should remain selected so we can immediately drag (or use the arrow keys to move) it to a better location.
Currently, the new code is not selected and it is nearly impossible to separate it from the existing code, for example if a complicated snippet is dropped on an already complicated block diagram.
(Not everybody has a gigantic screen to resize the existing BD for plenty of whitespace. I also often only have a small strip of the BD showing, with the explorer window containing the "droppee" on top. Dragging the snippet to the BD invariable ends in a complete mess.)
