6 | |
2 | |
2 | |
2 | |
1 |
Local Variables. When a VI has a hell of a lot of Controls or Indicators, creating a Local Variable can be a pain. The list to choose from can get very, very long, sometimes so long that it needs a scrollbar.
The current method of selecting which control a Local is connect to looks like so:
All in all, not too bad. I like the alphabetical ordering, and the fact that you can type to choose one.
However, from this image you have no idea what datatype each of these variables are (the name helps a bit). I suggest adding the Data Type and Control/Indicator information to this menu like so:
You can now easily see that "Params" is a cluster control, "XY Graphs" is an array of Refnums control, and "Vg Points" is an indicator array of I32. Notice that the datatypes are color coded and look similar to the block diagram icon.
In addition to this simple display change, it would be nice if there were an option somewhere in the preferences that sorted this list in different ways. Perhaps two different options: 1. First by Alpha, then by Type - or 2. First by Type, then by Alpha.
For those of you who prepend a data qualifier to the beginning of your controls and indicators (such as "str_Input1" or "dbl_Numeric"), this will still help you via the color coding. Plus you probably don't do that for ALL your controls, ones that end-users will be modifying when you release your code.
