13 | |
11 | |
3 | |
3 | |
2 |
Our facility runs only one version of labview at a time and that majority of time for installing a new version is spent removing the old version. A check box on the installer to remove or update the previous version would be a great addition. In recognizing that several companies must support multiple versions of labview removing the previous version should just be an option, not required. 2nd having the option to select all toolkits and addons to install from the first disk then just a prompt for the other install disks as needed would really speed up the install process as well.
