11 | |
7 | |
3 | |
2 | |
2 |
Hi.
I suggest an ellipsis be added to long enum or text ring values if they don't fit in the control. As it is today long values are line-breaked at last fitting hyphen (for instance):
Instead I'd like as much text as possible to be displayed with an ellipsis at the end. The above example would then become:
Cheers,
Steen
