Motivated by the comments to this idea I'll try to submit a suggestion to somehow save old lingering, almost dead, ideas. This isn't limited to the LabVIEW Idea Exchange, but there is no "Ideas General" topic, and it is an idea
. Here goes...
When posting an idea it's quite demotivating to so often just being pointed to a "similar" idea that is several years old and often hasn't gotten any obvious attention from NI back then. Sure, that old thread might touch on something similar, and it would be wise to put the old and the new idea under the same umbrella somehow, to not fragment the Idea Exchange. But, LV versions and abilities have probably changed in the meantime, and the new idea often hasn't been discussed in the years old thread. Of course one could have posted in the old thread anyway, but usually in discussion boards threads are deemed dead when they haven't received any updates for 2 years or more. My hunch is that a new post, however novel, would just drown there, so it isn't worth the effort. Too much of that and I won't be posting anymore here. Enough of that, and the Idea Exchange will die eventually.
I suggest that NI somehow mark "interesting" threads so they can live a life outside of limbo. Not "Declined" nor "In development", but maybe "Noted, more input wanted"?. What do you suggest - maybe just a better way to search and group ideas, to allow fresh threads about similar ideas to pop up while maintaining that virtual umbrella?
Cheers,
Steen
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined. #irony
